error-cause
DefinitelyTyped icon, indicating that this package has TypeScript declarations provided by the separate @types/error-cause package
1.0.8 • Public • Published
error-cause Version Badge
github actions coverage dependency status dev dependency status License Downloads
npm badge
An ES-spec-compliant shim/polyfill/replacement for the .cause property on all Error types that works as far down as ES3
This package implements the es-shim API “multi” interface. It works in an ES3-supported environment and complies with the proposed spec.
Getting started
npm install --save error-cause
Usage/Examples
const assert = require('assert');
require('error-cause/auto');
try {
		x();
} catch (e) {
		const actual = new Error('a better message!', { cause: e });
		assert(actual instanceof Error);
		assert(actual.cause === e);
Tests
Clone the repo, npm install, and run npm test
Package Sidebar
Install
npm i error-cause
Weekly Downloads
15,557
Version
1.0.8
MIT
Unpacked Size
31.7 kB
Total Files
55
Last publish
Collaborators
  • ljharb
